air compressor not building pressure
Old 04-23-11, 09:57 AM
F
I have a Craftsman Portable comp. 125 psi max when I turn the unit on it will start and run but the pressure on the gauge never gets above 25PSI and the compressor will run forever if I let it.
I have seen this question online, but no solutions. Thanks.
Old 04-23-11, 12:55 PM
GregH's Avatar
Super Moderator
Received 44 Votes on 42 Posts
Welcome to our forums!
There are a few possibilities but we would need to know exactly what type of air compressor you have.
Is it an oil-less, oil type direct drive or oil type belt drive.
The exact model and a link to what you have would help.
What other symptoms are you seeing?
Old 04-30-11, 03:00 PM
F
Craftsman 125psi 1HP 3GAL Direct Drive Oil Lubricated Cast Iron Cylinder Model 921153101 Serial 781378
Thanks.
Old 04-30-11, 03:20 PM
F
No other symptons. I made sure it was plugged directly to the wall and not an extension cord. It worked all winter as I was a nail gun to put up tongue and groove ceiling. Put it away and then went to use it and it wont go over 25PSI.
Old 04-30-11, 04:02 PM
B
I have the same problem
My Craftsman compressor is model #919.155611 It's a 1.5 HP 12 gal permanently lubricated Fusetron.
I noticed air leaking out of the flow valve, so I replaced it. Nothing changed.
The compressor starts up fine and sounds normal, but stops building around 20 PSI.
It worked fine last week.
Old 05-01-11, 04:17 AM
Old 02-18-14, 12:28 PM
B
Post Found the broken reed valve
I followed the thread and found a broken spring steel reed valve, but have not been able to find a replacement.....any suggestions? Wel-Bilt 2 HP with 20 gal tank...
