Craftsman Leaking Outlet pipe
Old 06-12-11, 07:35 PM
L
http://www.searspartsdirect.com/part...dMod=919153030
I have a problem with the leaking outlet pipe contraption. Parts number 27,31,30.
I can't seem to find where the 30 seals to the pipe it is just hanging there. I have used teflon tape to prevent the leak but it still does. The pipe is good, just number 30 is leaking but I can't even find a seal for 30 that is the problem.
On the part that goes into the tank, #27 has a copper seal.
But on the part that connects to the cylinder, #30 has no seal. I don't know how it worked before but somehow it's leaking now.
Old 06-13-11, 05:07 AM
I
It is possible that the ferrule is gone from the pipe or it needs to be replaced. Many of the air fittings have a nut with a ferrule on the pipe. The nut tightens down on the ferrule and squeezes it to a tight seal
on the pipe and against the male treaded pipe.
