motorising a screw jack
Old 06-17-11, 02:55 AM
A
i hane a screw jack (manual).
i've got a 2hp motor
what else is reqd to motorise the jack. names of components
drawings or plan will be helpful
Old 06-17-11, 04:53 AM
chandler's Avatar
Welcome to the forums! First question....why? You will need 750 to 1 gear reduction unit to overcome the speed of the motor. Over all the unit will weigh about 50 lbs. You'll need a way of moving it, aligning it with the shaft of the jack and allowing it to move as the jack moves. OR, you could buy an electric 1/2" impact driver, fit it with the appropriate socket and do what the normal lug nut wrench would do. (provided it has a nut and not an incorporated handle) We'll wait for the "why" thingy first. Unless you use this thing every day, I would just use the wrench that came with the jack.
Old 06-17-11, 10:51 AM
Received 1,178 Likes on 1,136 Posts
I've used all kinds of attachments on mine - speed wrench, cordless drill, electric impact wrench, pneumatic impact wrench - all of them work fine for me.
I'm with Chandler, the 'why' behind your request is going to be important.
Old 06-17-11, 11:28 AM
W
Motorized Jack
Would one of these fit your application?
Powered Jack Trailer Jack | etrailer.com
