Accu Rip Circular Saw Guide - Thumbs Up or Thumbs Down?
Old 07-13-11, 01:11 PM
P
While browsing videos on the net for DIY rip guides I saw a video showing the Accu Rip guide (available at HD).
Is this something that the casual DIY user might find beneficial or a product that leaves a lot to be desired?
Old 07-13-11, 03:59 PM
chandler's Avatar
I move too fast (for an old guy) to be fitting and unfitting my circle saw to a rip guide. I figured that's why I have a table saw. Even if I need to cut larger pieces of board, I can "rough" cut them 1/4" long and finish them on the table saw. I couldn't in good conscience give any thumbs up on it.
BUT, if you see a need for it in your plans, it does appear to be a well made product for the price.
Old 07-14-11, 05:30 AM
When I have to rip something that is too big or unhandy for my table saw I'll often clamp a 1x to the wood and use it as a fence........ not that I'd try to talk someone out of buying more tools
Old 07-14-11, 06:50 AM
W
Ripping
I use a small table saw to rip narrow stock.
For ripping a sheet of plywood lengthwise, I clamp an 8 ft. straight edge to the stock and use it as a guide for my circular saw. Just my 2 cents.
Old 07-14-11, 07:16 AM
ray2047's Avatar
When I was in the business I hardly went a day with out using a circular saw rip guide. I had a hard and fast rule never buy a circular saw unless I could get a rip guide to fit it. However I'm not familiar with the one you posted. I always just use the ones that fit in the shoe slots.
I seen a few alleged pros using a hooked thumb and the results were wavy as hades.
Old 07-14-11, 08:27 AM
P
Received 1,628 Likes on 1,461 Posts
I don't think I have used that particular brand but I have used similar and found it to be more trouble than it was worth. I use the guide that comes with my saws for narrow 1"-6" strips but when trying to use a similar guide out much further it easier to tilt the saw and get a wavy line so I clamp a guide board/bar to the material I'm ripping.
Old 07-14-11, 08:52 AM
B
Patience is what most contractors don't and can't have, time is money, so cut it and move on. They also have enough practice, experience, and tools to do a great job when needed and a fast good job when not. If your work will allow the time, you can't beat set-up.
I needed to finish cut the bottom of a bunch of doors and running them through the table saw wouldn't work. So I mounted a longer piece of 3/4 to the bottom of my circular as a new base so it would provide a steady guide and clamped a straight edge where needed. Prep took some time, but once set-up, the job went fast and the results were perfect.
As for the guide mentioned, the story above was very successful because the guiding surfaces were long and stable. Extending a guide out 16" to the side of the circular, IMO, would present a lot of binding problems. 4 or 5" not bad, but when you get way out there she is going to bind so be prepared to hang on and kiss your cut goodby. As I said, my opinion.
Bud
Old 07-14-11, 02:05 PM
I have worked behind a few carpenters that had that 'hooked thumb' for a guide and was always amazed at how good they did. Personally, I can't master it and since most of my carpentry work is done at home - I'll stick with my table saw
Old 07-14-11, 03:26 PM
ray2047's Avatar
Of course the big thing is a sharp blade. I have see carpet layers cutting off the bottom of doors with a blade so dull it almost took two of them to push the blade through.... no guide either. Geeze just looking at the bottom of the door would have made a sailor seasick it was so wavy.
Old 07-14-11, 06:12 PM
chandler's Avatar
I can, and have done the finger thingy. I use my index finger doubled back. I also use a left handed saw, so it can make a difference. I don't do it often, because of the cheap wood we are forced to work with nowadays will splinter too easily and the splinters wind up in my finger
Old 07-16-11, 11:00 PM
P
I appreciate all the replies.
So I bought one at Lowes (satisfaction guarantee plus veteran discount) and gave it a try. I have six sheets of plywood that need to be ripped to a 36-inch width.
It took a lot of fiddle-farting to attach the guide to my Dewalt due to the ribbing on the top of the foot. But after relocating the bevel adjustment clamp to clear the rip guide, I made my first rip down the long edge of a sheet of plywood. Worked great! Except I was 1/16 off because I forgot to include the blade width in the setup.
I found that when the guide is attached to the saw, it's a hassle to find somewhere to put the saw between cuts.
I took the guide off and put it back on a couple hours later. Still a hassle. The clamped guide method began to look more and more appealing. And cheaper! And more versatile. So I made an 8-foot rip guide custom-set to my saw by using the methods in videos that I found on the internet. Penciled my cut line, clamped the guide in place and let 'er rip (bad pun, I know).
Then I put the Accu-Rip guide back into its packaging and will return it in a couple of days, and get my $30 back.
And the OL will be happy about that .
