replacement blade for B&D mm525 mower
Old 08-22-11, 01:39 PM
I
Hi,
I was given a black&decker electrical mower (mm525, type 4). It's missing the blade. I am trying to figure out what replacement blades are compatible. I am cheap so I don't want to buys a blade, instead I want to find a broken mower and cannibalize it. So it it just the length and the size and shape of the whole in the center that determine compatibility?
Thanks!
Old 08-23-11, 05:26 AM
P
Received 2,217 Upvotes on 1,979 Posts
The blades for electric mowers are different than those for a gas powered mower so the blades are not really interchangeable. By the time you made an adapter, arbor or spacer I think it would be cheaper & easier to just buy the correct blade.
