Hammer drill - Core drill pilot bit "rubber thing"
I need to buy assorted sizes of the "rubber things" that hold the pilot bit in place while initially core drilling concrete. I'm talking about the temporary pilot bit that keeps the hammer drill from bouncing/spinning out of place before you start drilling the hole (and after which the pilot bit and rubber thing can be removed).
I can't think of a good name for what the rubber ring is called, and so I can't google it. What's the correct name of the piece and would Home Depot sell them, or do I need to go to a hardware/power tool specific place?
Thanks
Thanks
What size core drill are your running? Our core drill is like a portable drill press that we bolt to the floor to keep it from moving.
If you are using a core drill with a pilot bit on a hammer drill, just drill a hole the same size as the pilot bit. Then chase it with the core drill.
It's a portable Bosch hammer drill. The pilot bit I'm referring too isn't a real pilot bit just a removable point to get the hole started like in the right "hole saw" in this picture: http://www.coptool.com/wp-content/up.../corebits2.jpg. The one site I just saw referred to it as a center pin.
And the one rubber piece functions the same as the clear plastic piece here: http://www.unika.co.jp/en/products/c...es/crd3_hc.jpg
....... And I found it, it looks like a guide plate: Milwaukee 2 in. Guide Plate for Thin Wall SDS-Plus Core Bit-48-20-6157 at The Home Depot
Sold online only though. I'm not even sure if it'd fit my bit.
I stand by my previous post. That $5 guide plate is not going to help you much other then find the center of the circle. It is made out of plastic.
I still say find your center, drill a pilot hole for your pin to go into, change to the core bit and drill away.
I don't think the pin bit stays/screws into the core drill, I think it just sits there in a spring loaded hole. The rubber holds it in and also keeps it from bending/breaking from a bad angle when you're drilling? or not...?
I mean as long as it won't bend/break and I'm holding it against the concrete drilling I guess it's unnecessary..
Yeah, the link I posted was for a plastic one, the one I already have (for a 2" hole) is rubber. It's the same piece though, I'll probably call Grainger in the morning and see what they carry.
Thanks man
Thanks man
