Saws with good turning ability
Old 06-16-14, 04:31 PM
P
Hello, I'm new here and if I'm being honest, not particularly knowledgeable on saws or most tools.
I'm attempting to cut wood from an old pallet into a state shape and am having difficulty. As you can imagine, attempting to saw a state outline involves lots of twists and turns which I've not been very successful with using my current hand saw (Black & Decker).
Is there a type of saw that is very agile with easy turning ability in technical spots? My current saw cuts well and I have no complaints other than I'd like to be able to cut the state outline a bit more accurately. Thanks for any advice you may have!
Old 06-16-14, 04:55 PM
Received 1,422 Votes on 1,315 Posts
Welcome to the forums.
You really need a power scroll saw for what you are doing.
Sears power scroll saw
Old 06-16-14, 06:04 PM
P
Thanks a lot for the advice. How thick of a piece of wood would you think appropriate for that particular scroll saw? (most pieces I have in mind are around an inch thick)
Thanks again!
Old 06-16-14, 06:22 PM
pugsl's Avatar
Received 75 Votes on 68 Posts
Read the description on posted saw says up to 2 inches, Plan on a lot of blades for thick wood.
Old 06-16-14, 07:39 PM
Tolyn Ironhand's Avatar
Received 303 Votes on 262 Posts
If you want to keep it cordless (manual ) maybe a coping saw would work. Cutting inch thick wood would be quite a chore though.
Old 06-17-14, 12:02 PM
W
Received 29 Votes on 26 Posts
Curved Cuts
I suggest a band saw for cutting curved shapes from the lumber thickness you reference.
Old 06-17-14, 03:12 PM
Received 384 Votes on 340 Posts
Also the thinner the blade, the better you can turn the radius.
