Repair question for dewalt air compreser
My air compressor isnt building pressure in the tank, And there is air coming out of the cold start valve, I have replaced the check valve, but it is still leaking air, It seems to be coming out below the switch box, from a small brass looking valve, can it be anything else ? Or am I on the right track, thanks !!
Maybe give us a model #.
Mine has a very small plastic return hose that sometimes will spring a leak at a compression fitting.
