The latest combination machine.
Received 0 Votes
Yep. A combination miter saw and table saw.
Miter / Table Saw Combination
Make sure you watch the videos. My favorite parts are the miter gauge on the tablesaw, because the miter saw just isn't good enough. And the interior door they rip down in the second video.
I didn't watch the videos but I'll add my comment.
Generally, combination machines are built to save space or because someone cannot afford several different machines. As such the combination machine is a compromise and while capable of doing many different operations it can't do most anywhere near as well as the dedicated machine would.
Just my opinion.
Just my opinion.
Got one, Brant
Delta unisaw with run off table has a Jessem router set up built in. Niize! I don't know droo, with no "table", how can they call it a table saw. Sure it may rip small, short molding, but it is very limiting.
Received 0 Votes
Haha. I know. It looks absolutely insane. I have to say, tough, after watching the videos, I think this might be worthwhile for a flooring guy. Other than that, it looks crazy to me. And for a DIYer who doesn't know much and thinks this is a good idea, it is probably dangerous.
I didn't watch the video but the pic makes it look like an awkward tool
30 yrs ago I bought a shopsmith mainly because it allowed me to have a bunch of tools I wanted with one purchase .... I rarely use the lathe, I bought a stand alone drill press because I got tired of switching it over and it hasn't been out of the table saw mode in over 20 yrs. While the shopsmith is a well built machine if I had it to do over with I'd have bought separate tools.
Hold the presses! Droo may have a good point regarding flooring installers. Small wood, skinny wood, short pieces.....ideal for that, and could be carried on a bicycle
Other than that, I think it is a gimmick. Is it even UL approved? Direct drive motor will fail in 3,2,1. I've got two Ryobi portable saws piled up in the barn with burned motors. Saw is $299, motor is $215.
Wow that thing has "Harbor Freight Knock-off" written all over it. Probably find it on sale next year for $189!
I never thought I'd ever see a "tablesaw" more dangerous and inadequate than a Shopsmith...
While I agree a stand alone table saw may be better, what exactly don't you like about the shopsmith? Despite the fact that I've cut the tip of my thumb off with it, I don't see where it's anymore dangerous than any other table saw.
I've had mine for 30 years and while my shop was crammed in a corner of my basement I did a lot of good work with it. But most of the jigs I built for use with it were not to make tasks easier or results better--they were to increase safety. The Shopsmith table is too small to control stock larger than 12". The fence is too short and doesn't lock solidly in place. The table is tilted for bevel cuts. All these limitations increase your odds of a kick-back.
It has its niche for small home shops but considering how expensive one is, if you have the space you can buy dedicated machines for the same money.
I agree the table could be larger and I think they make retro kits that enlarge the table's footprint. I set up roller stand to give me the extra width/length when needed. If I had it to do over I would have bought separate tools but for the most part I've been satisfied with mine.
I haven't been able to bring myself to get rid of mine. It does a couple things very well--the variable speed 12" sanding disc is better than anything else you could buy and for rare cases when horizontal drilling is needed, nothing else comes close. If I ever try to make anything other than scraps using the lathe I'm sure I'll appreciate it even more.
I'm glad I kept it because my future retirement seems to be changing. I've been looking forward to spending a great deal of my free time out in my 24x48 shop but lately it looks more likely that I'll retire to my lake cottage and will have to downsize everything so it can fit in part of an unheated garage. Goodbye Norm Abrahms, hello Roy Underhill
Probably the main reason I bought mine was because of the lathe feature but aside from playing with the lathe when I first bought it - I've never used it. I was ignorant enough to think I had no real use for a table saw and that is the main thing my shopsmith has been used for since I've had it.
