Compressor won't shut off
Received 0 Votes
I have a Campbell Hausfeld 6 Gallon Compressor from 2013 and it is continuously running. It does hold air when I turn it off and was working fine yesterday. What should be the first things I check?
What does the gauge read? Is it reaching the cut off pressure? It's presumably compressing air, so where is the air going? Could be something like the pressure switch not doing its' job, letting it run up to the setting on the safety valve, and being expelled there. Or it could be a leak in the tank, a fitting, hose, or elsewhere, preventing the air in the tank from reaching the cut off pressure.
Received 0 Votes
the tank gauge read 150, 150 is the cut off point. but it kept running like it wasn't there so how would I check the pressure switch, and in terms of looking for leaks do I just feel around all the fittings for air?
Check the spec's on your particular unit, but the maximum pressure for a single stage air compressor is typically going to be in the 110-125 psi range. And it seems likely that the safety or pop off valve would have a maximum rating of 150 psi or less. This is the brass stem with a small hog ring in the end of it, and it should have the maximum pressure stamped in the body. Yes, as it continues to run you should feel air escaping someplace, likely around this valve, and/or maybe someplace else. If you have been running it at 150 psi though, you may have cooked the valves in the head.
Received 0 Votes
When it hits 150 psi it will hold there for a second and then it makes another sound like another fan or motor is turning on and does not continue to build pressure.
The tank is rated at 150 psi max with the valve stem being rated at 170 psi max
That sounds like the relief valve opening at 150psi.
150psi is way too high for that little compressor. As someone mentioned.... the valves may be cooked. I'd agree with that.
Do you have the type of pressure switch with the lever on it ?
If you need help addressing the pressure switch you need to give us a picture of it or the model number for the compressor. http://www.doityourself.com/forum/el...rt-images.html
Received 0 Votes
the model number is mw250000.
Also I have a question that might seem stupid, but can anyone explain why they would plaster the "150 psi max" all over the thing, let it go up that high, and give it a relief valve that is way too high?
Also I might be a bit confused about what a relief valve does but my relief valve does not have excess air coming out of it or "pop" when it hits 150. The sound I am referring to sounds like it is coming from "inside" the plastic housing. Would a video or a audio recoding of it happening help?
You may just be hearing a leak. I see where CH states 150psi max for that compressor. Single stage compressors are rarely run at that pressure because they weren't designed to go that high.
I couldn't find any useful info on your compressor about normal operating pressure. I did find one retailer that still has the pressure switch available for that unit. You may need to call CH technical services and ask them about the operating pressure issue. There number is in the manual below.
Manual can be found here...
CH power/IMAGES/pdfs/manual07/634000_0811-web.pdf
Pressure switch if needed....
WL052900AV PRESSURE SWITCH
