cutting 55 gal steel drum to make bbq
I have 2 steel drums, one had coconut oil in it, the other oregano oil.
Firstly, will this blade work on a circular saw to cut them in half? http://www.amazon.ca/gp/aw/d/B0030XM...W9L&ref=plSrch
Secondly, do I need to wash them out? I don't think these oils are explosive.
Lastly, would a cutting blade on a grinder be better? I'd feel safer using a circular saw I think.
I'd think a grinder would be quicker/easier. IMO if using a skil saw a fiber blade would be better. Something like this - http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
I wouldn't think the oil residue would be an issue.
Yes, that blade should work and cut pretty quickly. You could also use a diamond or abrasive carborundum blade but they leave a pretty good sized burr and generate a impressive shower of sparks.
Over the years I've set so many things on fire that "probably" wouldn't burn that I no longer risk it. Whichever blade you choose I would wash the barrels out before cutting as the cutting will generate a lot of hot metal sparks that could ignite the oil.
I think I would choose the metal cutting blade over the fiber blade. I have had fiber blades disappear when cutting sheet metal because the metal edge turns them to dust.
Be sure to double up on your hearing protection. (muffs and plugs) They don't call them screamer blades for nothing.
I've used my straight drive Milwaukee circular saw to cut steel a lot and it's still alive and kicking. But, it's my beater saw so I also use it for dry cutting stone, tile and bricks with the resulting thick clouds of dust. So, when if it ever dies I probably will not know the true cause other than operator abuse.
Just looked at the price of that blade. I'd probably try a steel plywood blade* backwards on the circular saw. Have a helper spritch a little WD40 as you cut. I'd cut from one end.
*I used plywood blades that had become to dull to use to cut plywood. Never cut a barrel but have cut a stack of several sheets of corrugated steel roofing this way.
Grinder blade is probably cheaper but a bit worried about grinder kickback. I spsre if the blade is spinning upwards, the kickback would be into the drum and not back at me.
Seems easier to stand to the side of a circular saw than to the side of a grinder.
