Best type of nailer for quarter round and baSeboard
Old 08-09-15, 07:40 PM
N
I have a brad nailer. Uses 18d to 1-5/8 in max. PrOblem When I've used it on baseboard, Admittedly only a couple of times , it doesn't really seem to hold flush against the wall. I want to put down some quarter round, and replace all the baseboard in the house. But I want something that's going to hold it flush against the wall, unlike the few times I've used this one. My question is, am I using the wrong tool, or should this be able to work fine from my needs? Should I get a finish nailer instead? If so, what should I be looking for? If not, what am I doing wrong? Thanks for your help.
Old 08-09-15, 08:09 PM
XSleeper's Avatar
Received 720 Votes on 666 Posts
Personally, I won't buy a brad nailer that won't shoot 2" nails. Yours should be fine for nailing quarter round to the baseboard (or floor). Depending on how thick your baseboard is, a 1 5/8" nail may not be quite long enough. Either that or you're missing the studs.
Old 08-10-15, 06:50 AM
Received 79 Votes on 74 Posts
Need a finish nailer, brads do not have heads and have little holding power.
Old 08-10-15, 08:25 AM
Received 94 Votes on 83 Posts
You are pushing the board flush before nailing right? I've seen people assume the nailer would pull the two pieces together but it will only hold them.
Old 08-10-15, 09:01 AM
Tolyn Ironhand's Avatar
Received 223 Votes on 196 Posts
18ga brads have heads, and I would recommend a 18ga 2" brad nailer. IMO finish nailer is too big for most trim work. Pins for a pin nailer do not have heads and are 23ga.
