Chip hammer bit stuck in my post hole
Old 03-29-16, 09:34 PM
I wasn't sure which subforum to post this in but I am building a fence so I thought I'd put it here. Out of 22 holes for my garden fence, 1 had a lime stone (I think) boulder.
So, I rented a chip hammer and started drilling and chipping away. Everything was going great, I was almost done, and then the drill but stuck.
It is a long bit and not in super deep, maybe about 7 inches or so. I've tried a pipe wrench but since there is so much bit on the outside, it just wants to bend around instead of turning.
Any and all suggestions are welcome!
If there is a better forum, tell me and I will see if I can delete or move it, thanks!
Old 03-29-16, 10:15 PM
Received 510 Votes on 480 Posts
It's moved.
Chip hammer = hammer drill. Is this a big one like a jackhammer or like a large drill ?
You tried disconnecting the drill and turning the bit in reverse and it just bends ?
Old 03-29-16, 10:16 PM
XSleeper's Avatar
Received 301 Votes on 274 Posts
I'd release it from the jack hammer and give it a few whacks on the side with a sledgehammer.
Old 03-29-16, 10:23 PM
It is not a huge tool, maybe like an extra large drill. I wouldn't compare it to a full-size jack hammer. Maybe I'd call it a mini-jack hammer. The guy at the rental shop is the one who called it a "chip hammer." Personally, I've heard a similar device called a "hammer drill" like you suggest.
Yes, I tried disconnecting the drill and turning the bit in reverse but it just bends around. About 2/3 of the bit is protruding from the rock.
As for giving it a few whacks on the side, it is too deep in a hole for the sledge to fit at all. Maybe I can tap it with a framing hammer or the mini-sledge sideways. This is somewhat far down at the bottom of a hard-won fencing hole after all!!!
Old 03-30-16, 05:16 AM
Norm201's Avatar
Received 118 Votes on 108 Posts
Send us a pic. Maybe if we see it we might be able to come up with some ideas.
Old 03-30-16, 06:35 AM
Tolyn Ironhand's Avatar
Received 73 Votes on 65 Posts
I have found you can get them unstuck by bending side to side or pulling while the hammer is running. Is it a drill type bit or just a pointed spike?
Chipping hammer:
[ATTACH=CONFIG]64478[/ATTACH]
Jack hammer:
[ATTACH=CONFIG]64479[/ATTACH]
Old 03-30-16, 07:18 AM
XSleeper's Avatar
There is surely more than one chisel bit in the box, isn't there? Disconnect the one that's stuck and use a different bit to break the other one out.
Old 03-30-16, 07:42 AM
Temporarily Suspended
Don't stick the second bit.______________
Old 03-30-16, 11:16 AM
pugsl's Avatar
Received 29 Votes on 27 Posts
Pull the bit out several times while it is cutting. It will help it not getting stuck.
Old 03-30-16, 02:49 PM
GregH's Avatar
Super Moderator
Received 19 Votes on 19 Posts
Hopefully you have it out by now.
If not what make and model is the tool?
Old 03-30-16, 04:40 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
If rental I'd say return the rotary hammer to save rental fees and just pay for the lost bit. Then rent a pavement breaker (AKA electric jack hammer).
Old 03-30-16, 05:03 PM
Thank you all, but I broke the bit off in my attempts. Luckily, the rental guy ate the cost. We didn't sign any agreement so I doubt he had any leverage over me in the first place. But, I was prepared to pay for it anyway--lucky me and lesson(s) learned!
Old 03-30-16, 07:33 PM
czizzi's Avatar
Received 9 Votes on 7 Posts
Not to be holier than thou, but I would have paid for the bit I broke and struck it up to a learning curve. No reason the retailer should have eaten something that was your fault. Cheers to the retailer.
