Wiring Craftsman compressor up for 240V
Received 0 Votes
I've had my good ol' trusty Craftsman 20 Gal compressor (model #: 919.176730) you years now. It has a dual voltage motor (MO-6340) but it's always been wired to 120V.
I recently added a 240V line to my garage and successfully changed most of my dual voltage tools to work with that voltage, however I'm having a hard time changing this compressor to 240. I'm attaching the pictures of the "wiring diagram" from the motor and a couple of pictures of the insides of the wiring box. The diagram puzzles me because it looks completely different from the actual wiring. For example I don't see any "orange" wires....
Any help is greatly appreciated.
-Gabor
-Gabor
Received 0 Votes
**These models have dual voltage motors, 120 and 240 volt. They are WIRED FOR 120 VOLT but can be converted to 240 volt operation. Instructions for connecting the motor for operation at 240 volt can be found printed on the inside of the motor cover or on the nameplate of the motor.
The conversion instructions are not in the manual. They will be on the back of the wiring cover on a MO-6340 motor.
Received 0 Votes
Thanks everyone for taking the time to reply. I took the wiring plate off again, just to make sure that I didn't miss anything and there's absolutely nothing on the inside of it - no diagram whatsoever. I think I might just have to take apart the motor to identify the wires coming out of the 2 windings. If anyone has any further information that might help, I would greatly appreciate that!
