Toro Lawn Mower Drive Wheel Pinion Assembly
I have Toro Lawn Model 20041 self propelled mower. While mowing, the left rear wheel pinion gear snap ring came off the shaft and pinion gear slid off drive shaft AND key and compression spring were lost. I have replacement parts but am not sure how the compression spring and key are assembled before sliding on pinion gear. Toro manual and figures are too small to be any value in installing the key and compression spring. Where and at what orientation are those two pieces supposed to be installed on the drive shaft.
