Can I cut wood with a angle grinder?
Old 01-11-17, 06:57 AM
I'm limited on tools and I need to cut my 7ft tall Christmas Tree in half for disposal.
The only tool I have is a angle grinderDEWALT 7 Amp 4-1/2 in. Small Angle Grinder with 1-Touch Guard-DWE4011 - The Home Depot. It has a thin metal cut off disc.
Old 01-11-17, 07:02 AM
Received 786 Upvotes on 689 Posts
I don't know if it will cut wood very well or not. Nobody you can borrow a saw or hatchet from?
Old 01-11-17, 07:05 AM
I guess I could borrow a saw.
Old 01-11-17, 07:07 AM
Even a hand saw will work. As long as you cut 2/3rds of the way thru you should be able to snap it in two.
Old 01-11-17, 07:13 AM
All right I'll get off my lazy butt and get a hand saw. Thx Mark.
Old 01-11-17, 07:07 PM
Received 126 Upvotes on 111 Posts
One like this will go thru it like butter, but that's all it's good for is cutting limbs.
https://www.walmart.com/ip/1112519?w...&wl13=&veh=sem
Are you a guy and your trying to avoid buying a new tool?
Hmm.
Old 01-11-17, 07:18 PM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
A bow saw or decent pruning saw would make short work of it. They also have the correct teeth for cutting un-dried resinous wood. Don't try a back saw or rip saw. Won't work very well and will gum up quickly.
Old 01-12-17, 06:58 AM
Yes I prefer not to buy a new tool. I ended up putting the whole tree on the curb for trash pick. Today is heavy trash day so hopefully it will be gone when I get home.
I'm not buying a real Christmas tree for a long time..
Old 01-12-17, 08:15 AM
V
Received 2 Upvotes on 2 Posts
Shucks . . . . I was hoping to see how much pitch and resin you could accumulate on that cut-off disc.
