Are all tap and dies standard sizing?
I was given a bunch of industrial taps and dies, with a small assortment of dies and several handles. Since it was free, I accepted them, but as the assortment is relatively small and jumbled and the source was industrial, I'm wondering if I can source any future bits and pieces I need or if each brand has their own sizing.
Not sure of the manufacturer of these but one of the die wrenches is marked "Reishauer" The taps all seem to be way bigger than anything I'd ever use.
Is it worth keeping or will I end up spending more trying to make them work in a non-industrial setting?
Thanks.
Thanks.
Thread sizes are either metric or standard, There are several different sizes but thread cuts are to a common standard. Sizes will be stamped on dies. something like this 3/8 or 10, post what is the most common type here and we can tell you what you got.
Correct, SAE (English) or Metric assuming we are talking standard machine threads.
I've got several sets but for my personal use they simply don't get used that much and when they do typ I'm cleaning up a thread vs making new. But when you need one they are very handy.
If you have actual "industrial" parts they may be of higher quality than the tools you would by retail. I would not be throwing away, just fill in the blanks as needed!!
If your taps and dies are marked with a thread then that is what they are. There is some tolerance allowed so there can be a very slight variance even from the same brand but most people can't measure or even notice the difference. Taps and dies can wear with age but unless they saw hard use you probably would not notice a difference in the dimension of the threads. You'll likely notice that they are dull and don't cut as well.
