Create a jigsaw like motion with an electric motor?
I like to create a rock/stone sifter. I found this YouTube video
https://youtu.be/yVrIgGAO_-s
tutorial and I think they're using a jigsaw to run the sifter. I want to purchase this electric motor and run the sifter. However, I like to know what accessories I would need to convert the rotational motion into a jigsaw like motion. Electric motor recommendation is also appreciated.
I don't think you'd find the parts you need in a store... those parts are custom fabricated for jobs like that. The first place you might check would be Ebay.
Most better saws, whether jig or reciprocating have the capability of two motions. Linear and oscillating. One may be better for your application than the other. Just for info.
I once made a power sifter. I made the sides of a box out of wood and stapled hardware cloth to the bottom. Then I strongly attached an electric motor to the box. On the motor's shaft I attached a steel arm so when the motor spun it was out of balance and caused the whole box to shake. Then I hung the frame with ropes so it could shake/vibrate freely.
Actuator
Would this linear actuator works for what I wnated to do?
It will take a little bit of time and creativity, but, for overall strength and durability, I don't think you could beat something like either the diagram that Wirepuller made or the description that Pilot Dane provided. Maybe it's my conservative nature, but I don't see a jig saw lasting too long with the extended run time that I think you're looking for.
aka pedro, exactly. That is why I don't want to go the route of a jig saw. It may ruin the jig saw. Thanks!
I used my shaker for heavy duty soil sifting. One was for sifting/sorting compost while the other was used on a firing range to recover bullets from the soil. In both cases dirt was loaded in by the shovel full and it proved quite durable.
