Air nailers
Old 05-01-17, 04:54 PM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Air nailers
Hi All, what does the angle have to do with the air nailers 21* 30* etc. which would be the best for framing interior 2X4 partitions.
Geo
Old 05-01-17, 06:40 PM
XSleeper's Avatar
Received 1,810 Upvotes on 1,628 Posts
The more angle a gun has, the shorter the magazine will usually be. So a 30 degree gun is nice for zigzaging your way through framing. 21 degree guns have a long magazine but are often the kind of guns used when full heads are required... full head clips are longer, thus the longer magazine will hold more nails. I suppose professional framers might say they are better balanced in your hand as well.
Me, I'm happy with my 30 degree Paslode.
Old 05-01-17, 07:54 PM
Received 1,231 Upvotes on 1,179 Posts
Once you settle on an angle, make sure nails in that angle with the right collation are easily available; some are more rare than others.
Old 05-02-17, 01:09 AM
F
One other thing to keep in mind is that SOME jurisdictions do not allow the use of clipped head nails for certain areas. I solved that problem by buying a gun that shoots full-head nails. I think it is a 20 or 22 degree angle, Porter-Cable from a factory rebuild place. Cost was significantly less than a new gun and has worked well for me with my limited usage.
Old 05-02-17, 02:59 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
I have both Bostitch (28 degree) wire bound nail guns and a Senco (21 degree) gun which shoots round head nails (usually Paslode plastic bound). I am almost having to carry extra ricks of nails in my left hand because the magazine is emptied so fast in comparison to the Bostitch which has a longer magazine.
Old 05-02-17, 05:15 PM
Geochurchi's Avatar
So it appears that the angle has more to do with magazine size than anything else, I think i may go with a Harbor Freight 21* nailer as this is a one time project and I have had pretty good luck with some of their tools,definetly will go with round head nails.
Geo
Old 05-03-17, 03:53 AM
Received 785 Upvotes on 688 Posts
I have a HF 28° framing nailer and it works good for me BUT for the most part they are disposable nail guns as very few parts are available for repairs
