replacement bolt Porter Cable compressor
Old 05-04-17, 08:51 AM
150 psi 6 ga Pancake air compressor
I lost the bolt that is on the bottom of this unit and is used for bleeding air and moisture from the tank. I dont need a OEM bolt and it doesnt need to have that slit in it... I just want to plug
it up. I t seems to be about an 8 mm but not quite....I cant tell what threads it has....
anyone know what size it is and the thread so I can get one at Home Depot...??
Old 05-04-17, 08:55 AM
Received 786 Upvotes on 689 Posts
Is it a bolt or a petcock? There is usually only a few different size petcocks and it shouldn't be a big deal to find a replacement - they're universal, not brand specific.
Old 05-04-17, 08:59 AM
https://www.newegg.com/Product/Produ...g&gclsrc=aw.ds
this is it but I only want the size so I can get a 2 dollar bolt to plug it up for good...
I only want the inner bolt...
Old 05-04-17, 12:50 PM
Doesn't have to be that one [which is overpriced]
https://www.lowes.com/pd/Kobalt-1-4-...**-Kob/3414734
https://www.tractorsupply.com/tsc/pr...a?cm_vc=-10005
It's important to routinely drain the tank. That prevents moisture build up in the tank which can both corrode the tank and get in the air supplied to your tools.
