How to make hole in an iron rod with drilling machine.
Old 06-19-17, 03:10 AM
P
I have to make a hole in an hallow iron rod. I have to make atleast 6mm hole so that I can put a nut and bolt through that iron rod. I have a drilling machine of Bosch of model GSB 500RE. I had indicated where I have to make hole on the t. I also attach
Old 06-19-17, 03:27 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Cut a v notch in a 2 x 4 and clamp to drill bench Clamp rod to bench and 2x4.
Old 06-19-17, 03:37 AM
P
these are the photos
Size:  29.2 KBName:  IMG_20170619_120911.jpg
Size:  40.1 KBName:  IMG_20170619_120916.jpg
Size:  39.3 KBName:  IMG_20170619_153530.jpg
watch the photo tell me any suggestions.
Old 06-19-17, 04:02 AM
Norm201's Avatar
Received 693 Upvotes on 616 Posts
What Pugsi says. A drill press would make it easier. If you shove a wood rod into the pipe, it would help keep the drill straight as you go through the wall to the other side.
Old 06-19-17, 05:13 AM
P
Received 1,951 Upvotes on 1,747 Posts
First, start by making a pilot hole with a small drill bit. The drill may want to walk off the round face of the pipe but with skill you can hold it in place or you can make a small flat spot with a file. Once your small pilot hole is drilled then move up to the drill size you need.
Old 06-19-17, 06:01 AM
W
Received 61 Upvotes on 53 Posts
Drilling Holes
What you have is called pipe. Looks like either galvanized pipe or black iron pipe.
Make sure you use a bit for drilling metal. Your bit assortment includes masonry and wood bits.
Old 06-19-17, 06:48 AM
P
thank you all for quick replies. i don't know anything about drill bits. i searched net but further confuse me. there are a lot variety of drill bits like HSS bits, cobalt bits, titanium bits, step bits etc.., etc.., also there are lot variety of sizes. i ready to buy some drill bits. kindly suggest me which type of drill bit is required for my work and also tell me which size.kindly suggest the drill bits that are compatible with my drilling machine.once again thank you all for your response.
Old 06-19-17, 08:48 AM
P
You can use the drill bits shown in your picture. The silver group in the center are masonry bits, do not use them. The group on the left and right can be used. I would start with a 3 or 4 mm bit then enlarge the hole with a 6mm.
Old 06-19-17, 10:41 AM
P
I tried with both the left and right ones. U can see the tip of no 5 bit on the left of masonry bits is very sharp and pointed while the 6 and 8 no bits tip got blunted. That is due to my trying on that iron pipe. Also the 2nd bit on the right ones is broken and reason.... Yes you guess it right.. So please help me. I know that I don't have right bits.
Old 06-19-17, 10:55 AM
Received 785 Upvotes on 688 Posts
Small diameter bits are easy to break, even more so if the piece being drilled or the drill isn't stable. Doesn't take much wobbling to break a small bit. I'm partial to colbalt bits. They drill steel better than the standard high speed bit.
Old 06-19-17, 01:37 PM
W
Bits
The bits on the left are brad point bits and are not for drilling metal.
Old 06-19-17, 08:49 PM
P
I plan to buy drill bits. Kindly guide me in buying.
What type of material I have to buy?
What shape of drill bit I have to buy?
What size drill bit I have to buy?
Old 06-20-17, 05:32 AM
P
Get twist drill bits intended for drilling metals. Its tip will look like the bit in the middle. What type or brand will depend on how many holes you need to drill. If just doing a couple than almost any will work. If you want them to stay sharper longer you can look for cobalt, Ti or black oxide coated...
Old 06-20-17, 06:17 AM
W
Bits
Adding to Dane's post above:
https://www.lowes.com/projects/woodw...-guide/article
Please read the entire article.
