3/8" 25ft Air Hose/Reel
I'm looking to buy a 3/8" air hose reel with 25' hose for my garage. It's been a while since I've purchased air parts, so I'm looking for some recommendations. For instance, what brands are the best, which ones to avoid (Cox Reels, Reelcraft, Speedaire). I thought of going with a 50' hose, but I really don't need that much length. Plus I don't want any more pressure drop than I can help. I see seemingly similar ones ranging from $79 to $300 even amongst the same brand. Not clear what the difference is.
BTW, the reel will be wall mounted, and the reel/housing needs to be all metal (no plastic).
If I find one I like with a 50' hose, can I swap the hose with a 25' or is the hose a fixed to the reel?
How critical is it that the fittings on the reel are 3/8" (I see some with 3/8" hoses that have 1/4" fittings)? Seems like 3/8" hose should have 3/8" fittings.
I had.... the key word is had.... two different reels. One was a pretty good one but always leaked a little air. The other one wouldn't lock the spool where it was stopped.
I ended up hanging the hose on the wall.
Ive lived with that hose real for 30 years and just picked up a 50' 1/2" reel that is all mounted but have been waiting for the weather to warm up a little so I can do the copper plumbing.
Just stay away from the cheap Harbor Freight junk and you'll be fine. I picked up a new Coxreel on eBay for $90 that retailed for $175 so I cant wait!!
That is how I have my garage plumbed, 3/4 copper.
Have always used 3/8 hoses but opted for 1/2 for the new reel.
The only concern is the fitting needed to get from the 1/2 hose male thread to the 1/4" quick connect, it may be a bit a bit large hanging at the end of the tool.
I was thinking of using a short piece of my 3/8 hose to have a short whip to keep that fitting away from the tool.
It's been up since spring and gets a lot of use.
Honestly, if I were going to do it again I would probably just go with 3/8" hose.
I know there is a pressure drop but that 1/2 hose is heavy and bulky and now that winter has set in, it's stiff and always has the coil set.
That big block of brass to get the 1/2" thread to 3/8" is not a problem but just have to be aware as the hose rolls up so you dont get KO'd!
I think I'll got with 3/8" then.
Has anyone ever used Pex for compressed air? It has a maximum rating of 160 psi at 74 degrees. I already ran 3/4" copper in the garage, and it would great to transition to Pex inside the basement ceiling and over to the compressor a few feet away. I would put a PVC sleeve around it in the exposed/vulnerable areas, which would only be about a 5 foot vertical section under the stairs down to the compressor. Soldering overhead in tight spaces in very close proximity to wood framing while standing on a ladder is not very fun. It would only be about a 2ft horizontal run and a 5 ft vertical run, so very small amount of Pex.
