Good cheap laminate trimmer?
I'll most likely only use it this one time to replace some old laminate sheeting on a counter in the basement. What's a good cheap laminate trimmer? I'd rather not spend a lot, but from the looks I'm going to have to spend close to $100 or so?
Then what bit do you need to finish off the laminate edges?
Thanks
Thanks
Do you have a router, They have blades for routers. Here is one from harbor freight.
https://www.harborfreight.com/14-in-...ter-62659.html
Make sure it has a blade with it.
