Campbell Hausfeld 26 gal compressor
I have an electric Campbell Hausfeld air comprssor that will not run. I have been reading on-line posts but I can't find one that says how to test if the problem is the pressure switch or the pump motor. How can I by-passing the pressure switch to test the motor ?
Welcome to the forums.
There should be a pressure switch with a removable cover where you can check.
There are several different models so I can't give you any further info without a model number or picture.
How-to-insert-pictures
