8 1/4 in compound miter saw blades
Received 0 Votes
hello,
i have a 8 1/4 in compound miter saw, i was wondering if i can use an 8in blade???
i use the saw mostly for just quick cuts , junk wood, cutting up pallets for firewood. nothing important. i have about 9- 8in blades from my grandfathers table saw just lying around doing nothing.
i have an 10in sliding compound miter saw that i use for anything important.
thanks for any input
john
john
Doubtful there would be any problem using them. Worst part is that old blades like that are just sharpened steel... not carbide... and as a result, they will not cut as quickly or easily. This can cause wear on the saw... especially if the pallets are oak. If you find yourself having to push too hard, use a skilsaw with a cheap carbide blade instead.
