Bosch Brute jackhammer
Old 02-20-19, 09:03 AM
Exclamation Bosch Brute jackhammer
I just purchased a really clean used Bosch Brute jackhammer. I gave it a try breaking up my basement floor (what I bought it for) and the results are disappointing. It's slow to break through.
My thinking is that lubing the shaft of the bits might help a little as will sharpening the bits.
Any thoughts? Is it just not that powerful a machine or will lubing and sharpening have a big effect?
Thanks guys.
Old 02-20-19, 09:21 AM
XSleeper's Avatar
Received 669 Votes on 619 Posts
It's possible that it might need service, but it's also possible that you expect too much. Making a hole in fresh concrete takes time. Once you have a hole it will chip off pieces but if you are making a hole it's slow going until you get a good sized hole going.
Old 02-21-19, 06:21 PM
Yeah, working better now. It was a combination of working from an edge and a sharp bit which doesn't bounce around like when it was dull.
