In ProcessAdSlots.php line 39: Trying to access array offset on value of type null
Canít put cordless Hitachi Drill together
Old 08-26-19, 01:52 PM
U
So... I wonít go into detail about why I thought I needed to take my drill apart let just say Iím an idiot. So now itís opened up and apart and while I was taking it apart the insides fell out of place and one piece is getting in the way of putting it back together since I found out I didnít need to take it apart in the first place. TIA for any advice.
Old 08-26-19, 01:59 PM
Geochurchi's Avatar
Received 78 Votes on 73 Posts
Hi, really hard to tell from that pic, needs to be clearer .
Geo
Old 08-26-19, 07:57 PM
Received 1,186 Votes on 1,098 Posts
Picture needs to be close to the circled area. Try to make a little larger.
It looks like the commutator area where the brushes attach.
The model number of the drill would be helpful too.
Old 11-08-19, 10:59 AM
U
Thanks guys for your replies.. I was able to put the drill back together but I am still unable to get the drill bit out. Iíve tried all the methods to unlock it (except the one that uses WD40 sprayed in it for like 10mins) but nothing seems to work. Thanks for answering though.🙂
Old 11-08-19, 03:34 PM
W
Received 21 Votes on 20 Posts
Use two large lock-joint pliers to loosen the chuck.
