What cutter do you recommend for 1/8" steel cable?
Old 06-03-20, 06:55 PM
A
I really need to buy something tomorrow if possible (we have a Lowe's and Home Depot nearby). The cutters I'm seeing on their sites don't mention steel cables. Can someone help?
Old 06-03-20, 06:59 PM
XSleeper's Avatar
Received 931 Votes on 850 Posts
I have always used a grinder and cutting wheel.
Old 06-03-20, 08:35 PM
Received 1,505 Votes on 1,393 Posts
I'm assuming..... stranded steel cable..... like the vinyl coated type ?
You can use side cutting pliers too. I use my linemans pliers.
Just one example..... Linemans pliers
Old 06-03-20, 11:27 PM
Received 98 Votes on 86 Posts
Lots of choices - a bolt cutter would make quick work of it as well.
Old 06-04-20, 02:22 AM
Received 403 Votes on 359 Posts
A cut off wheel would be my first choice, bolt cutters my second.
Old 06-04-20, 03:02 AM
T
Received 40 Votes on 38 Posts
As you're buying something, I suggest an angle grinder which has many uses.
Old 06-04-20, 03:03 AM
Doorman2722's Avatar
Received 26 Votes on 26 Posts
In the garage door world we use these, they will cut up to 3/16" Felco cable cutter
Old 06-04-20, 03:38 AM
B
Received 111 Votes on 97 Posts
I use a right angle grinder with a metal cutoff disc to cut cable. Before cutting I place 2 Ubolt cable clamps where I need to cut. This prevents the strands in the cut cable ends from unraveling. Another approach if you have a torch. Solder the cable in the area of the cut, then make the cut.
Old 06-04-20, 05:35 AM
P
Received 892 Votes on 822 Posts
I use cable cutters when installing cable railings. They are very quick and easy to use and leave a very clean cut. Angle grinder, cutoff wheel, bolt cutters will all work but leave messier cuts.
Old 06-04-20, 09:40 AM
R
I use a hack saw and a vise. Works very quickly and cleanly if the blade is tight against the vise.
