Cutting a 4x4 with an 8 1/4" circular saw
Old 06-23-20, 02:46 PM
Can you cleanly cut a 4x4 in ONE PASS with an 8 1/4" circular saw blade ?
Thanks
Old 06-23-20, 04:18 PM
Marq1's Avatar
Received 370 Votes on 345 Posts
It's a test!
4x4 post is 3 1/2 x 3 1/2 but the blade is going to have some portion that cant cut due to shaft or shield clearance, so the answer is probably no, I know my 10" miter saw will!
Old 06-23-20, 04:39 PM
Received 77 Votes on 72 Posts
Sure that's not 7-1/4 not 8?
Still the answer is no.
Old 06-23-20, 08:13 PM
XSleeper's Avatar
Received 675 Votes on 624 Posts
No, but you can with a 12" miter saw.
Old 06-24-20, 02:58 AM
Received 321 Votes on 285 Posts
I always use a 7.25" skilsaw along with a speed square. If you make 3 passes using the speed square the cut should come out perfect. [turning the 4x4 after each cut]
