saws - dust collection
Old 06-26-20, 10:27 AM
maarkr's Avatar
Received 8 Votes on 6 Posts
I want to get a large shop vac and hook it up with hoses for my table saw, cutoff saw, and have a hose for general cleanup. I saw some parts online with clamps, shutoffs, Y pieces and hose. It's in my garage (700 f2) that I park the vehicles, but I just want to collect most of the dust when I use them. The connection for the saws is 2 1/8". It will be only abt 6-8' between the vac and the saws.
Can I get away with using 2 1/2" hose gating off the hoses not in use? I cannot find a connector to pressure fit into the 2 1/8 id exhaust ports on the saws. You would think it is something readily available? Am I missing something here? Any advice appreciated.
I did see some dust collection kits online but most were commercial/ industrial.
Old 06-26-20, 12:12 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
I used a shop vacuum for dust collection for a little while. found out I was cleaning out filter almost every time I used it. there are dust separators that people have used with some luck. Am looking for a larger setup like that for my home work shop. Here are some ideas for you
https://www.google.com/search?client...w=1261&bih=659
Old 06-26-20, 02:43 PM
maarkr's Avatar
y, i was looking at some smaller units... wondering if a 1HP unit is enough? and looks like I'll need to go with a 4" hose?
Old 06-26-20, 04:07 PM
Marq1's Avatar
Received 377 Votes on 352 Posts
Even a really big shop vac will be overcome with wood chips quickly, do a searching on Craig's List for some type of duct collector, it will work much better!
Old 06-26-20, 05:34 PM
Tolyn Ironhand's Avatar
Received 210 Votes on 186 Posts
You can look around the plumbing aisle. You may find parts you can use. Also, check where they sell vacs. A lot of times they have adapters that will get you from vac to pipe.
I have used a shop vac with a "dust deputy" for my table saw to catch the sawdust and I can say I HIGHLY recommend it. I kid you not, 99% of the dust goes into the bucket, not the filter. Another handy thing is a footswitch or remote control to turn the fan on and off.
Examples:
Dust deputy: https://www.amazon.com/Oneida-Molded.../dp/B002JP315K
Power Tool Remote: https://www.grainger.com/product/21R...!470952775171!
Footswitch: https://www.harborfreight.com/power-...tch-96618.html
Dust collection parts: https://www.amazon.com/Shop-Vac-8017.../dp/B00004T180
Old 06-26-20, 06:54 PM
C
Received 97 Votes on 76 Posts
I had a workshop for 20 years. I had all the stationary tools. When I set up the shop I considered a central vacuum system but then I decided that since I wasn't doing commercial production work I would try just vacuuming with a shop vac after I finished work. That worked pretty good so I never installed a vac system. I never had a problem with my shop vac not being able to handle chips - probably mostly because my shop tools made sawdust not chips. Stuff from my jointer and planer was no problem for the shop vac.
Old 06-27-20, 03:41 AM
Norm201's Avatar
Received 234 Votes on 209 Posts
Although I no longer do much with my saw or wood projects, I also just use my shop vac. I just wedge the intake hose to the saw exhaust and it seems to work well. I clean it out once a year and reuse the old filter. Hose it off and let it dry in the sun.
