CP air impact wrench not working
Old 07-21-20, 11:31 AM
D
I have a CP air impact wrench CP 340 that is not working and releasing air out of the trigger. I plan on taking it apart to see what I can do. Can I use WD 40 to oil this ? I need some recommendations. Thank you
Old 07-21-20, 11:45 AM
Received 321 Votes on 285 Posts
WD40 works well for flushing out the crud that accumulates.
Old 07-21-20, 11:54 AM
XSleeper's Avatar
Received 676 Votes on 625 Posts
True, but you dont use wd40 for lubrication, if that is what you're asking. Air tool oil is a thin non detergent mineral oil.
Old 07-21-20, 01:40 PM
Marq1's Avatar
Received 372 Votes on 347 Posts
aka Central Pneumatic / Harbor Freight
dont get hopes up too high, probably an internal seizure, not like it was a quality piece to start with
Old 07-21-20, 01:57 PM
H
Received 95 Votes on 84 Posts
Meh, I've found HF to be more "Kalashnikov" design specs-
If it it stops working, whack it with your hand a few times to loosen - something... .
If that doesn't work, take it apart, put it back together again, oil it, and it usually works.
Old 07-21-20, 02:00 PM
I bought a low torque HF impact 35+ yrs ago. I bought it because it was only $20 and at that time I didn't know anything about impacts other than I wanted one. I keep telling myself the next one will have more torque ..... but mine refuses to die.
