Air compressor fittings
Old 10-02-20, 08:43 AM
A
I picked up a new silent air compressor that has 1/4 quick connect fittings on it. Can I remove them, or put an adapter on them for a quick connect 3/8 fittings and hose?
Old 10-02-20, 10:37 AM
Received 1,118 Votes on 1,038 Posts
If the compressor uses screw in fittings..... I see no reason why they couldn't be removed and changed. You'd need a 3/8" female x 1/4" male NPT coupler.
Reducer coupler
Old 10-03-20, 09:25 AM
A
thanx - kinda figured that... Would work, just empty faster....
Old 10-03-20, 10:05 AM
A little faster.... it's still reduced thru that fitting.
Old 10-04-20, 05:33 AM
GregH's Avatar
Super Moderator
Received 37 Votes on 35 Posts
Just so you know, the effect of upsizing the quick connect fittings would be insignificant.
For common air tools you can readily get 3/8" ID hose with 1/4" fittings that that would not restrict air flow to any measurable amount.
marksr voted this post useful.
Old 10-04-20, 07:21 AM
GregH's Avatar
Super Moderator
Was curious about flow rates and came up with this chart.
I am not familiar with the compressor you mention but generally the largest capacity compressor you can operate off of a 120 volt, 15 amp receptacle is about 6 cfm @ 90 psi.
The chart clearly shows that 1/4 " air line.can support 10 cfm.
If you wanted you could get a 3/8" inch ID hose with 1/4" fittings and have a bit of overkill.😊
