custom double end bits?
Old 11-19-20, 03:57 PM
B
looking for something i cant find. the type of bits that fit in the multi screwdrivers.
looking for a 1/4 bit with the ball with a #2 phillips and a t10 or allen on the other end. would be very convenient for me
Old 11-19-20, 05:04 PM
XSleeper's Avatar
Received 714 Votes on 661 Posts
They aren't mix and match. So you might as well just get a 9 in 1 or a 7 in 1 that you like and put your #2 phillips on one end and your T10 on the other so that you can just pull it out, and flip it end for end.
Old 11-20-20, 06:02 AM
P
Received 681 Votes on 628 Posts
You can not have a double ended bit with a ball. The size of the ball needed to fit a locking chuck does not leave room for a working tip. There are double ended bits but they are intended for magnetic holders but you will not find a double ended bit with a locking ball.
