Which Type of Nail Gun?
I want to nail plywood flooring onto rafters but I've never used a nail gun before. Do I need a finishing or framing nailer? Electric or pneumatic? Rent one or buy one and sell it when I'm done?
You didn't say, but if the flooring is only going to be used for storage you only need a hammer since you will be using very few nails, just enough to keep the wood in place with no movement.
I would not buy a nailer if you don't think you will have a further use for it. I would go old school and use a hammer and ring nails.
Besides, pounding nails with a hammer can be very therapeutic.
Norm201
voted this post useful.
For nailing subflooring down you would use a framing nail gun. Pneumatic is really only an option if you have an air compressor.
Thanks to all who responded. I intend to use the space for storage so I'll try to do the job with an old-fashioned hammer and nails. If my aging arm gets too tired I'll use a drill and wood screws.
If there is a finished ceiling below, I would go with driving screws instead of hammering nails to avoid any cracking, etc. especially if it is a plaster ceiling.
Balrog49
I'm in an old farmhouse where the interior walls are lapped boards, lathe, clay & horsehair mortar, then plaster & paint. I've got a big compressor, so I DO use a nail gun, or a pin nailer/stapler. They are REALLY useful because they drive the fastener into the wall in one shot; repeated hammering just makes the wall fall apart (don't ask me how I know)
Quick tip - If you use any type of pneumatic nailer, add ball valves to the male connectors of your air hoses.
When you have 1or 2 nails/pins/staples that are JUST just outside the reach of the air hose, you close the valve, undo the quick-connect, and there will be enough high pressure air in the hose to drive those last few fasteners. Even the tiny yellow plastic coil hoses store enough air for 2 shots from a small pin nailer.
2john02458
