Digital calipers
Old 12-07-21, 12:26 PM
Norm201's Avatar
Received 594 Votes on 531 Posts
Digital calipers
I have this Harbor Freight Pittsburgh digital calipers. Their cheap, but for my purposes they do the job. However, there is this annoying gap at the very tip of the lower jaws for outside measurement.
Without any expensive tool is there a way of closing this gap? Perhaps using a wet stone or a fine file. I seldom need to use the very tip. I mostly use the upper section that does mate neatly. No, Im not buying a more expensive one. I just dont need it. Just looking for suggestions.
Old 12-07-21, 02:41 PM
B
Received 181 Votes on 161 Posts
I believe that would destroy the accuracy of the internal measuring jaws because you would create an overlap.
CircuitBreaker voted this post useful.
Old 12-07-21, 02:59 PM
P
Received 1,560 Votes on 1,403 Posts
I think weld the tip and build up the missing material. Then file/grind/hone the tip back to the proper shape. Precision work can be done by hand but it's slow, careful work.
Old 12-07-21, 03:03 PM
Norm201's Avatar
You're probably correct.
Old 12-07-21, 04:51 PM
Tolyn Ironhand's Avatar
Received 594 Votes on 510 Posts
As long as you measure from the same location of the caliper it should give you a correct measurement.
Option: Buy another one from HFT and then return the bad one.
va_scubadiver voted this post useful.
Old 12-07-21, 06:36 PM
Norm201's Avatar
Don't temp me. LOL
It's over a year old and truth be told suspect they're all the same.
Old 12-08-21, 04:41 AM
B
I would not consider welding due to the great possibility the thin steel would warp and ruin the caliper. Also, unless I have a welder and surface grinder to repair the caliper, the cost of a new caliper is nothing compared to the cost of a welder and surface grinder or outsourcing these operations.
