Dremel multi-max
Old 04-14-22, 08:40 AM
E
Received 6 Votes on 6 Posts
Dremel multi-max
I have a Dremel Multi-Max MM40 electric cutting tool and I'm cutting some door trim with it. It keeps losing the cutting tool as I'm trying to cut a piece of thin wood. Why is it doing that? Thanks.
Old 04-14-22, 10:51 AM
Received 2,951 Votes on 2,663 Posts
Do you mean the blade keeps coming loose ?
The blades are keyed with a pins and multiple holes in the blade.
The retaining allen key screw usually has a lockwasher on it to keep it tight.
Old 04-14-22, 04:57 PM
Tolyn Ironhand's Avatar
Received 595 Votes on 511 Posts
Are you using Dremel blades? I have found that some blades from different companies do not play nice with other brand tools.
