Wen drill press: clamp all the way tight doesn't stop the table from moving
Old 06-19-22, 10:46 AM
Received 3 Votes on 3 Posts
I bought this Wen drill press and twisted the table clamp as far as I could until it reached the point where it felt like that little handle thingy could break.
Should I use a small cheater bar to crank it tighter? The table still has movement within its holder.
WEN 5-Amp 12 in. Variable Speed Cast Iron Benchtop Drill Press with Laser, Work Light, and 5/8 in. Chuck Capacity 4214T (homedepot.com)
Old 06-19-22, 11:25 AM
Tolyn Ironhand's Avatar
Received 597 Votes on 512 Posts
I have a similar Harbor Freight drill press with a similar build quality. In fact, after I first got it I broke the cast iron part that clamps onto the main tube.
Perhaps you could take a piece of shim stock like an aluminum can or soup can and put it into the holder to make up the slop.
Old 06-19-22, 12:01 PM
that's ingenious, problem solved, thanks!
