Cutting rebar / angle grinder questions
Old 05-24-24, 03:28 PM
E
Received 1 Upvote on 1 Post
I never used or really knew of an angle grinder till yesterday. Needed to cut and bunch of 1/2" rebar and a website mentioned that tool.
In the past, I'd use a hack saw or when at the store, borrow a bolt cutter from the rental department and cut the rebar in the store ; )
Got a dewalt angle grinder and some of the lower cost / thin disks to go with it (5/8" arbor).
I think I counted about 20 seconds to make each cut. Nice!
The disk showed minimal wear (I didn't measure a diameter change, just noting that the printing on the disk was still legible.).
Some questions:
For infrequent use, can I use a drill with some sort of adapter to go in the chuck to hold the disk? Lower RPMs, I realize.
A website said a drill isn't made for sideway pressure like that, but I don't really need another tool for the few times I cut rebar.
What other things do you use an angle grinder for? I'm 62 and been fixing things / pretty handy my whole life... but just recently got an oscillating saw (the little one with the blade going side to side... I've had a sawzall for years).. Didn't really know about that little tool but been using that sometimes that I'd use a jigsaw
At harbor freight today, they had air powered angle grinders.
Those used much smaller arbor diameters. and disks were smaller.
Any recommendations on disk diameter? arbor diameter? for a LOW cost angle grinder? And would that change if you'd say using a drill would be good for the few times I need it?
Have a great long weekend!!
Old 05-24-24, 04:51 PM
B
Received 314 Upvotes on 277 Posts
A drill doesn't have RPM for cutting discs or grinding wheels. If the DeWalt you mentioned is yours, that is a good angle grinder that will last you a lifetime. What is it's status?
EdShnatter voted this post useful.
Old 05-24-24, 07:07 PM
Received 4,103 Upvotes on 3,685 Posts
They have 4-1/2" grinders at Harbor Freight starting at $15. Can't get much lower cost than that.
They even have a decent Bauer grinder at $35.
Old 05-25-24, 02:43 AM
Received 870 Upvotes on 761 Posts
30 yrs ago I bought a $15 HF 4" grinder that worked well for 25 yrs. I replaced it with another one [$20] I also bought a B&D one from them back in the early 80s and it is still going strong. I like having 2 so one can have a grinding wheel and the other a wire cup.
I would expect a pneumatic grinder to require a lot of CFM.
In case you didn't know - you only need to cut halfway thru the rebar and then they will easily break in half.
Old 05-26-24, 06:16 PM
C
Received 26 Upvotes on 23 Posts
Applications for your angle grinder
- Use a 1/4” disc to grind metal down to shiny (handy for welding)
- Use a cup brush or wire wheel to remove paint
- You’ve already used a slitting disc
- Use with a flap disc
Just today i replaced a muffler and used angle grinders to remove rusted nuts and to slit the hangers. Your tool world just got bigger!
Old 05-29-24, 06:59 PM
E
marksr - yes, cut most way through and snap : )
again, being 62 and making it this far without one of these, I don't want to spend a lot. I'll pop for the Harbor $15 one.
I've used
https://www.harborfreight.com/6-piec...-set-1341.html
on a drill with fair results. a grinder version would get things done faster?
I made about 35 cuts all the way through 1/2" rebar. the 4 1/2" cut off disk for $2.50? i used likely got down to about 2" diameter. They are consumables : ) ?? Yeah, cutting 1/2 way through and snapping would get more life out of them...
Old 05-30-24, 05:04 AM
P
Received 2,270 Upvotes on 2,022 Posts
You linked a wire brush set. Make sure you pay attention to the RPM's. The wire brushes are rated for a max speed of 4'500 rpm but angle grinders run over 10'000. So, make sure you buy wire brushes intended for use on angle grinders.
Yes, the cutting disc is a consumable and periodically needs replacing.
