Speed Controller - Power Tools
Old 06-13-24, 12:43 PM
T
Received 2 Upvotes on 2 Posts
Anyone have recommendations for a specific model Power Tools RPM Controller?
Foot pedal vs. Rheostat pros/cons?
Presumably, the Foot Pedal is spring-loaded to return to the lowest RPM - is there any difficulty maintaining a constant RPM when necessary?
It wouldn't be difficult to build, but gathering all the parts is difficult and expensive...
Thanks for any thoughts,
Tom
Old 06-13-24, 07:15 PM
Tolyn Ironhand's Avatar
Received 912 Upvotes on 770 Posts
Google "power tool speed controller" and you will get many inexpensive options. Just know that running a motor on a power tool slower than its "normal" speed can cause the motor to overheat.
That said, I made up a speed controller using an old style dimmer and have never had an issue.
Old 06-13-24, 10:28 PM
T
Thanks, Tolan
Never thought of the Dimmer Switch...
Tom
Old 06-14-24, 10:02 AM
XSleeper's Avatar
Received 1,973 Upvotes on 1,770 Posts
I burnt up a palm router trying that once with a rheostat type of controller.
Not advisable.
Old 06-14-24, 05:33 PM
Don't use a dimmer. Only use a solid-state speed control.
