Removing Saw Blade
Old 08-13-01, 03:28 PM
I am having trouble removing the blade from my Delta chop saw. Is it a right or left handed thread bolt?
Even when I push in the shaft lock and try with all my might it seems like it's getting tighter? The lock has now slipped a time or two on the shaft and now the lock does not work as well.
Any ideas?
Old 08-14-01, 10:04 AM
Joe_F
An option might be to e-mail Delta and ask. Does the owner's manual cover replacing the blade?
I would go to their website and see if they have free downloads of instruction manuals. Many companies I have dealt with recently (Simpson Meters for one) had their stuff right on their website.
Most times if you call the 800 # on the saw, the folks there are very happy to help you out.
Old 08-15-01, 06:54 AM
some help
Delta....Black and Decker table saw or chop saw stop the blade from turning in the direction of the cutting teeth with a block of wood and remove the nut by cutting into the wood block....as the blade turns to cut the wood.....the nut will tighten as the saw is cutting a safty thing so the blade will not come off.....Good Luck
Old 08-16-01, 02:18 PM
So does that make it a right or left handed thread?
Old 08-16-01, 10:25 PM
some help
Hello WA JOE...again
That would be a left hand thread ..to tighten the nut/bolt....turn left to remove....sorry for not having said that earlyer......right hand = clock wise.....left hand = counter clock wise....Good luck
