Window Bench
Does anyone know where I can get simple plans for building a window bench in our master bedroom. I am new at wood working and need some simple.
Thanks for any help,
Gordon
Gordon
Don't know of any off hand. I have seen a few in some woodworking books. But if you want an easy way out, go to Home Depot or Lowes and buy some unfinished, prefab cabinets to use as your building blocks. One or two of the units that typically go over a refrigerator make an excellent base for the seat portion. Then you could get taller units to go on either side if you wish to provide extra storage and a place to set lamps, pictures, etc. Build a simple box base for each unit to set the cabinets on and screw them down to the floor/wall and connect them together to make a rigid window seat structure.
Secure 3/4 hardwood ply to the top of the seat portion along with tops on any side units you use. You don't even have to put hinges on the top since you have cabinet doors in the front. Finish it as desired. Cover a piece of thick foam cut to size for the seat, put some lamps on the side units and you have a window seat.
Note: If you have a central air vent where you are going to place the window seat, you will need to provide space in the base you build for the heat and air to enter into the room. You can either buy duct made for that purpose or just build a channel in the base that directs the air to an opening in the toe kick area of the base that you build. You can get little vents made for use in cabinet toe kick areas.
Also, check out some woodworking books for ideas and search the web for "window seats".
Good luck.
Good luck.
Hello
Do you have a Bay window you want to install the seat/bench in or is it going to be if front of a window on a flat wall....?
If it is going to be on a flat wall do you want it to have storage? like a window seat or do you want just a bench?
you you get back to us we can help you come up with a plan you will like....Thanks and ...Good Luck
I would love to help.... how big do you want to make it? Do you want to have a cushion to sit on? how wide is the window you will set it in front of? do you want it that long or longer/shorter? 24" front to back and 18" to 20" high and as long as you want.....It can look like a chest with the top opening or you can have it look like a low cabinet with doors that can slide or swing open, are you going to stain or paint it? a little more information and we can go to started..........Thanks
Hello GClarke
I have been looking through what I have nothing seems quite right...Do you want the seat to look built in, nailed to the wall or like a chest setting next to the wall....do you wwant moldings and trim or more of a box with a cushion on top? I am working on my doityourself.com e-mial address now as soon as it is working I will let you know....Thanks and Good Luck
