mower blades
Old 01-16-02, 07:48 AM
rs_petty
mower blades
I generally just use a file to dress up the cutting edges. What is the correct technique and how sharp does a mower blade need to be? How do you properly balance the blade after sharpening?
Old 01-16-02, 08:48 PM
Sharp Advice's Avatar
Admin Emeritus
Hello: rs_petty
There are several methods that can be used to sharpen a rotary mower blade. I suggest the do-it-yourself person use a table top or free standing belt sander. A grinder can also be used.
There are also several methods that can be used for balancing the blade upon sharpening completion.
The best way to insure a sharp blade is to sharpen it at the existing angle. Mower blades sharpened at too steap an angle will be sharper but not remain that way for very long.
The archives, {Prior Postings} within this forum have several topics on both these subjects.
Regards and Good Luck. Sharpening Forum Moderator
TCB4U2B2B Enterprises.
Accurate Power Equipment Company.
Complete Saw and Tool Sharpening Service.
Reminder: "Work Shop Safety Is No Accident."
Old 01-26-02, 09:55 AM
Re: mower blades
Speed and accuracy require removing the
blade and holding it in a vice or Workmate.
Axe-sharpening files wear out fast but are
generally best for mower blades. Wear gloves.
A mower blade is sharp when it becomes
dangerous, i.e. so you might cut yourself if
not wearing gloves. You probably need to
resharpen at least once a month during the
mowing seasoon.
