Drill bits
Old 01-31-02, 04:38 PM
Drill bits
What kind of drill bit is best on gal. pipe?
Old 01-31-02, 06:18 PM
Sharp Advice's Avatar
Admin Emeritus
Hello M. Clap and Welcome to our Do-It-Yourself Web Site and my Sharpening forum.
For most around the shop and or home useage, you can use an ordinary black steel bit or a chromed steel drill bit.
Regards and Good Luck.
Sharpening Forum Moderator
TCB4U2B2B Enterprises.
Accurate Power Equipment Company.
Complete Saw and Tool Sharpening Service.
Reminder: "Work Shop Safety Is No Accident."
Sharpeners Quote:
"I can sharpen almost anything, except your dull mind."...
Old 02-13-02, 08:34 AM
Kevin T. Tunnel
Mclap
Hello; I was reading all the good advice that is given on this forum. May I suggest that if you are drilling into a pipe that you use a punch to make a small dent into the pipe first, this will help with the drill bit from walking. Just a thought.
