Stuck Drill bit in key less chuck.
Old 05-19-02, 08:12 AM
Lionel
Hi
I have a robinson screw driver (hex shape shank) bit stuck in my drill. I removed the chuck but the bit is stuck in the spindel that the chuck mounts on. How can I remove the bit. Please.
Old 05-25-02, 06:36 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Hello: Lionel
The answer may be to put the chuck into a vise vertically and use either a strap wrench or water pump pliers to turn the chuck. Done correctly & carefully, little or no damage will occur to the outer surfaces of the chuck.
Old 05-25-02, 07:35 AM
Lionel
Unhappy re drill bit stuck
Thanks to those who have tried to help me . However it seem I can't write this properly. The drill bit is NOT stuck in the chuck. It is stuck in the spindel that the chuck mounts on to.
Old 05-30-02, 04:25 PM
rshep
place bit in vice horizontally, have someone hold drill whilst you tap spindle with hammer and drift.
rs 8)>
