masonary drill bits
Old 06-06-02, 12:19 PM
jbrid21
masonary drill bits
I got a drill and a pretty large set of bits. I am not sure which bits are the masonary bits. Can anyone help me out. Are they the copper looking ones or the sliver ones? New with drills. thanks for your help.
Old 06-06-02, 02:07 PM
Cool
This is one type of carbide-tip masonry bit. Usually silver colored.
Probably would be easier for you to identify them by going to a hardware store and looking at labeled bits, so that you would know exactly what you have.
Mike
Old 06-07-02, 06:34 AM
the_tow_guy's Avatar
Masonry bits can be a silver color or normal steel color. Normally the end of the bit is slightly larger than the shank and the carbide cutters are visibly welded to the tip.
Old 06-10-02, 09:40 AM
arthropod98
also, the spiral for debris removal is TIGHTER on the masonry bits i use -- vermont american -- cheap, can be bought at lowe's, and work GREAT!
