ADT Safewatch 3000
I need to reprogram my safewatch 3000 alarm system so that all my zones are armed in the stay mode. I have the keypad for reprogramming but I need help in how to program it. Please help me
Thank you
Thank you
You may be able to reprogram that system. I think that system is an Ademco V20P (my cross-reference has an ADT SafeWatch Pro 3000, but not SafeWatch 3000.) On V20's you can power cycle the system (power down - disconnect battery and unplug Xformer - then power up) and within 60 secs of power-up press * + # to enter programming. That's * and # at the same time. If you see 20 or Programming or something like that, you got in. You need to go to Field 56 to reprogram the zones.
Now, why do you want all zones to be armed in Stay? There's no logical reason for doing this. You can simply arm to Away and get the same thing. Of course, arming all zones in Stay mode means you can't move around without setting-off motions also. But, if you want it that way, that's how you do it.
Good luck!
Good luck!
