Disable Beeping - Ranger American
Hi,
I have a Ranger American house alarm that was pre-installed in my home when I bought it 4 years ago. Since then I have misplaced the manual and I do not know what model the control panel is. Basically all I want to know is how to turn the beeping off when you open and close doors. I had it disabled at one point but it has come back to life and I can’t figure out how to disable it again. I remember it was very simple like *1 or something to that effect.
Can you help or maybe point me in the direction where I can find the codes? It is a simple white model with very little features.
Any help would be greatly appreciated.
Thanks.
Thanks.
Ranger American is usually a DSC 1550 or 1555. On those models you have to press *6 - Master Code - 6 - # to enable or disable the chime. Try that if it doesn't work then look inside the main panel to see if you can figure out exactly what model you have.
Good luck!
Good luck!
