Brinks door sensor / magnet
I have a door that is binding. I will need to remove the magnet / sensor in the door ( not the wired portion ). This sensor is inserted into the top of the door pretty tiight. How do I remove this sensor so that I can replace it after I trim the door down a little ? The sensor is white in color, round about the size of a dime.
Thanks in advance.
Thanks in advance.
Yep, that's the magnet part of the sensor you're talking about. There's really only one way to remove the magnet if it's stuck in there tight - with force. I usually use a small, flat-head screwdriver (something small enough to squeeze in beside the magnet) and pry them out. If you're lucky, it won't be glued in (knowing Brinks - it's probably not.) All I can tell is to keep working with it until it slides out.
If you want to see what you're working with - take a look here. Click on the picture to the right to get a better view. Like you say, the part you are working with is the one that is not wired, the piece on the left in the pic. It's nothing more than a round piece of plastic housing a magnet, so there are no screws, nothing to hold it in but friction.
Just keep working on it - it will slide out sooner or later. You could also try drilling a hole in the top of it (a small one) and putting a screw in to it to pull it out, but that really shouldn't be necessary.
Good luck!
Good luck!
