how do I setup X10 module on a napco 9600 panel
Old 08-21-03, 05:58 PM
darrellhill
Unhappy how do I setup X10 module on a napco 9600 panel
Anyone know how to program an x10 module on a napco 9600 ?
I have install sheet setup relay boards 1,2,3,4 and housecodes a,b,c,d but cant make it zone follow or xmit any x10
Darrell
Old 08-21-03, 07:08 PM
Are you using the GEM-X10KIT and PC04 interfaces? I'm not a Napco expert, so I probably won't be much help.
I do know you must have a power-line interface to make anything X-10 work. Just using relays won't do it.
Give me some model numbers of what equipment you have and what you're working with so I can be of more help.
Good luck!
Old 08-22-03, 05:36 AM
darrellhill
Model numbers
I have a GEMX10 kit w/pco4 and install sheet
I have it wired and jumpered according to docs, but the only referances I can find about programing the module is to program as a 4 relay modulels but I cant find how to do that in the install book
Darrell
