alarm wiring
Old 10-17-03, 03:52 AM
dykemrtn
Red face alarm wiring
The mains wiring to the control panel,if i take it from the ring main will i need to put a fused spur by the panel,there is a spur inside the box,well a connector block with a fuse in it.
what about if i came from the lighting main or ceiling rose could i connect it directly to the control panel with out any need of a spur .......
Old 10-17-03, 09:30 AM
Alarm systems use Low Voltage transformers, so typically the transformer is plugged in to a nearby outlet.
That being said, it would really depend on the system you are installing and you location. Where is Wolverhampton?
